koa132435
Jul 16, 2022Star
HELP GS110EMX low Upload Speed when connecting at 2.5Gbps on ports 9 and 10
Hi All, I hope someone can help and point me in the right direction even though I think this is a software/hardware bug (I hope I am wrong). First - every time I connect on port 9 or 10 and c...
DaneA
Jul 20, 2022NETGEAR Employee Retired
What is the current firmware version of your GS110EMX? If ever its not yet the latest version, I suggest you to update it then observe if the same problem will occur. The latest GS110EMX firmware is v1.0.2.3 and you can download it here.
DaneA
NETGEAR Community Team
koa132435
Jul 27, 2022Star
The latest firmware, attached is the screen capture. Same problem.
Also, I connected an ASUS router's 2.5 Gbps port, and same problem with upload being throttled or rate limited.
The same problem across 2 x GS110EMX , and 1 x GS110MX. Monitoring on the switch and router shows 2.5 Gbps solid connection over 5ft of e Cat6 cables.
I already tried multiple cables, shielded and no shielded (The same 5ft cables work and support 10 Gbps with no problem).
- DaneAJul 28, 2022NETGEAR Employee Retired
Thank you for your response. Kindly try to enable Flow Control on ports 9 & 10 then observed if the same issue will occur.
DaneA
- koa132435Jul 29, 2022Star
I have exhausted all tests, enabling, disabling flow control, rate limiting,etc and same results.
I decide to find another switch, non-Netgear switch and the problem remained the same. So this ruled out the Netgear switch. I then decided to enable a shared folder in a desktop using a single 1 gbps port to eliminate the NAS device and I had the same problem with the upload speeds, it is capped/rate limited when I use the 2.5 Gbps port on the Netgear WIFI router.
At this point I may need to switch strategy and focus on the router, maybe the 2.5 Gbps speed on the LAN segment has a rate limiting đĄ.
Thank you DaneA
