sentur
Oct 18, 2023Tutor
Help setting VLANs on Netgear GS908E switch? Not receive an IP in the correct VLAN tagged IP range
I'm trying to set up VLAN tags on a Netgear GS908E switch. But I'm either not understanding or getting something very wrong. Here's a network diagram. VLAN tags are set on my gateway Unifi UDR. T...
- Oct 18, 2023
sentur wrote:
- UDM is managing the IoT VLAN and all other VLANs for that matter.
- It’s doing Gateway / Router / VLAN tag and network management and DHCP for all VLANs.
- UDM (LAN Port 2) is connected to Negear switch (LAN Port 1)
You must understand and know how your UDM is is configured providing the VLAN 1 and 20 on what becomes the trunk port for the GS908E. If you can connect a computer to this port, and you get DHCP from what is serving the VLAN 1, it's most likely not tagged. .
sentur wrote:
I think this is correct?
- VLAN ID 1:
- Tagged → Ports 1, 2, 4, 6, 7, 8
- Exclude → Ports 3, 5
- VLAN ID 20: IoT
- Tagged → Ports 3, 5
- Exclude → Ports 1, 2, 4, 6, 7, 8
Why oh why you changed all 1..8 to be tagged? It's only the trunk where you carry multiple VLANs which is all tagged (or one VLAN runs untagged).
- VLAN ID 1:
- Tagged → Ports 1 .. under the assumption the VLAN 1 is delivered as tagged. This is the de-facto standard for trunk links carrying multiple VLANs. It could be also used untagged for VLAN 1 with the PVID set to 1.
- Untagged as access ports → 2, 4, 6, 7, 8 with PVID set to 1
- VLAN ID 20: IoT
- Tagged → Ports 1 ... this will be your uplink carrying the trunk of VLAN 1 and VLAN 20?
- Untagged → Ports 3, 5 with PVID set to 20 ...
In general, I tent to suggest some "logical" port organization. Port 1 VLAN Trunk uplink, port 2...6 access ports for standard LAN 1, port 7, 8 access ports for IoT.
sentur wrote:
What’s the difference between Untagged and Excluded?
Excluded means the port is not participating in that VLAN.
Untagged means the frames leaving the switch on this post are untagged -and- the PVID defines the VLAN incoming untagged frames are assigned to.
sentur
Oct 18, 2023Tutor
Thanks Kurt.
- VLAN ID 1:
- VLAN ID 20: IoT
schumaku
Oct 18, 2023Guru - Experienced User
- VLAN ID 1:
- VLAN ID 20: IoT
- VLAN ID 1:
- VLAN ID 20: IoT
- senturOct 18, 2023Tutor
- VLAN ID 1:
- VLAN ID 20: IoT
Thank you. This makes a lot more sense to me now. As to what needs to be tagged and untagged in each of the VLANs.
Thank you for taking the time to explain it schumaku
- VLAN ID 1:
