Emma_Jenk73
Oct 10, 2022Follower
How much power does Plus Switch JGS524PE
Hi, I'm trying to establish the typical power usage of this switch. It's flashing like a Christmas tree most of the time and I have no idea what power it uses. I found the datasheet which says 123. B...
schumaku
Oct 10, 2022Guru - Experienced User
Review the Gigabit Ethernet Plus Switches Data Sheet FMI - everything available you asking for
Model JGS524PE
RJ45 ports PoE 802.3af PoE budget
24 12 100W
Power Consumption (when all ports used, line-rate traffic and max PoE)
Worst case, all ports used, line-rate traffic, max PoE 123.0W
