jsam2020
May 08, 2020Aspirant
How to access Netgear GS748TP
Hi I recently took over the management of an IT infrastruture and I am in the process of accessing devices with little access information. We have a Netgear GS748TP switch which is live on the ...
- May 11, 2020
Hi jsam2020 ,
Welcome to community !
For GS748TP the default management ip address was 192.168.0.239, you can use this ip address login switch by Gui( IE/Chorme broswer).
If your switch is configured with management ip address, you can install "Smartwizard Discovery utilit" tool on the PC and discovery your switch ip address.
Notes:
The PC and switch need to be on the same subnet.
kevin_hong
May 11, 2020Apprentice
Hi jsam2020 ,
Notes:
jsam2020
May 18, 2020Aspirant
Thanks
That did the trick!
