immapikatchu
Jan 11, 2023Follower
How to change IP Setting password
In ProSAFE Plus Configuration Utility, what is the password that you input when you have selected a switch and enter in the IP Settings? How can you change this password?
1 Reply
The previous configured password is typically what you are behind.
Keep in mind as a part of the continued security updates, the ProSAFE Plus Configuration Utility is obsolete, recently updated switches don't accept any configuration or password changes (unless this was explicitly allowed, permitting the old NSDP protocol access. Strictly focus on the Web UI available on all newer recent models for admin purposes as documented https://www.netgear.com/support/product/gs105ev2.aspx#docs (except of the obsolete ProSAFE Plus Configuration Utility).
