Wolfgang10
Jan 14, 2023Aspirant
How to handle: Total Received Packets Not Forwarded
I have an MS510txm switch.
At port 10 I have attached a sfp+ module with fibre (from 10GTek) operating at 10GB.
The link is connected to another switch witch is connected to PC.
The operation from PC over the link is working, but the detailed port statistic shows increasing numbers of "Total Received Packets Not Forwarded".
May be the performance over the link is related to this effect?
What causes the switch to not forward the packets? Is there a solution for that?
On the other ports I dont see this behaviour.
Regards
Wolfgang
1 Reply
- Wolfgang10Aspirant
There is also the same number of "Dropped Transmit Frames" seen at that port.
Any ideas?
