2bsd
Sep 10, 2025Aspirant
How To Hard Reset a GS108Tv3 Switch
I have a GS108T v3 switch that doesn't configure itself at 192.168.0.239 when it's connected directly to a MacBook, nor do I see any DHCP requests coming from it. If I put it on a network with a DHCP server I still don't see any DHCP traffic or its MAC address in the servers leases.
So, I'd like to try a hard (factory) reset to see if it will come back to life. Since I can't use the GUI without an IP address for it, is there another way to do a reset?
Once a Netgear Smart Manages Switch is configured to a static aka. fixed IP address, it won't go through the DHCP process, requesting a LAN IP configuration from the DHCP server.
Only in case the DHCP does not succeed, it will fallback to the default LAN IP address 192.168.0.239 .
If you really need it factory resetted -> https://kb.netgear.com/24679/How-do-I-reset-a-smart-switch-to-factory-default-settings
- 2bsdAspirant
That link made me hopeful, but unfortunately the GS108Tv3 switches are either not "smart switches" or they can't be reset to factory defaults, or the article needs to be updated...
The instructions say to find the hole for the "factory default" (or defaults) button, but the GS108Tv3 doesn't have said hole (unless it is under a label).
All GS108Tv[1|2|3] models have the same physical design with the reset button on the front panel in a hole for a paper clip end (or similar):
And it's -not- under a label.
