2bsd
Sep 10, 2025Follower
How To Hard Reset a GS108Tv3 Switch
I have a GS108T v3 switch that doesn't configure itself at 192.168.0.239 when it's connected directly to a MacBook, nor do I see any DHCP requests coming from it. If I put it on a network with a DHCP...
Sep 20, 2025Guru - Experienced User
2bsd wrote:The instructions say to find the hole for the "factory default" (or defaults) button, but the GS108Tv3 doesn't have said hole (unless it is under a label).
schumaku's screenshot shows the location of the hole. Did you look there? Also, can you confirm that you see a GS108T label on the upper right? Not just GS108?
schumaku
StephenB wrote:Not just GS108
...or a GS108v2, GS108v3, or GS108v4 - which are all unmanaged, and have no rest button for the obvious reason: There is no configuration to reset I'm afraid.
