tbarden
Feb 16, 2021Follower
How to provision Video VLAN on a GS716TP
We are trying to properly setup a GS716TP switch to support multicast Video using Newtek's NDI transport solution. Our other switches (GC108P's) have a default VIdeo VLAN that can be chosen (4089). T...
schumaku
Feb 16, 2021Guru - Experienced User
Earlier switch models don't come with predefined Video-VLAN and the related QoS settings. Of course, you could use IGMP Multicast configuration and Video VLAN on the Smart Managed Pro switches, depending on the expectations, results might vary.
Netgear switch platforms of choice for IGMP Multicast based AV including NDI transport are the M4250 AV Line Managed Switches and the M4300 Series as readily configured.
