hshah96's avatar
hshah96
I am trying to configure the Nighthawk as a access point
Hi   I am trying to configure the nighthawk, EX7000 as an access point but it isn't working. I have my router connected to the GS108PEv3, and this is wired to where the EX7000 is kept. I have conne...
  • JohnRo's avatar
    Dec 26, 2016
    Hello hshah96,
    Welcome to the community!
    First, you need to make sure that a computer can go online when connected to the GS108PEv3. See page 18-20 of the user manual, follow the steps on configuring the extender as an AP. It is better if you perform a factory reset first to make sure that any previous configuration will not affect the new setup.
    Thanks,
ProSupport for Business
