wally7100
Mar 23, 2017Aspirant
I have a GS728TXP-100NES smart switch that won't boot up. The power light just stays on yellow. i
I have a GS728TXP-100NES smart switch that won't boot up. The power light just stays on yellow. i would like to send it back for repair but i can't open a case because it isn't listed on my equipmen...
- Apr 14, 2017
"Accepted Solution"..
I recieved the replacement GS728TXP switch today and it boots up and seems to be working fine. I haven't installed it into the system yet, adn probably won't until next week but I can communicate with it on the test bench and everyting looks normal. I own two other switches from this family of switches and can't say enough good things about them. It is an excellent product series.
DaneA
Apr 11, 2017NETGEAR Employee Retired
Thanks for the update and you're welcome. I'm glad to know that a replacement switch was processed for you by NETGEAR Support. :)
Since you will be receiving your replacement switch soon, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
wally7100
Apr 14, 2017Aspirant
