brentbengtson
Dec 05, 2020Follower
I just want to know if I bought junk or if it can do this for me
I want to know if this switch can be configures as follows: 1) Have eight networks connected to it on ports 1-8 as follows: 1 - wired/wireless network internal to office with NAT internet acc...
schumaku
Dec 06, 2020Guru - Experienced User
Junk? Not sure what you expect from a L2+ Smart Web and Cloud managed switch currently on sale for less than 50 USD on Netger's Amazon Store these days.
Lack of much details, two points hit my eyes:
1. For port 2..8: "[2...8] - VLAN[2...8] management network with VLAN tag"
This reads to me as you try to create some fan-out of some VLANs to gain ("console?) access to where you can connect either a OOB device network port [eg. your F5s] on one and, and a port where you can ad-hoc connect computer to connect to that management/OOB network. For this purpose, you won't tag the traffic on the port, much more run the port [2...8] [U]ntagged on VLAN[2...8] and with PVID[2...8].
2. Port [1..7] VLANs " with NAT internet access through port 8"
There is no NAT support on these switches - only inter-VLAN L3 routing is available.
