DickDay0
Mar 18, 2016Aspirant
I need to update the firmware
I just received a new GS105PE and I'm told I need to update the firmware. I have downloaded and unzipped the firmware update to my desktop. (my Netgear router has dumbed down the firmware update so...
- Mar 20, 2016
Hi DickDay0,
I'm afraid that we're not that quite familiar with Ubiquiti devices particularly the instant 802.3af adapter you have mentioned if its going to be compatible with the GS105PE switch or any NETGEAR switch. We don't have any Ubiquiti device/s to try to test it to any NETGEAR switch/es. You may try to post your inquiry on the Ubiquiti forum site.
DaneA
NETGEAR Community Team
DickDay0
John, that is correct. I was trying it from the web interface, not the CD. It was suggested that updating from the web ui was somehow better than using the app. No idea why.
A Netgear WNDR4700 is my router and it goes to a Ubiquiti Edge-24 500watt switch, which powers the GS105PE. Based on the lights on the GS, it has .3at power. Port 5 link and activity lights are both solid green.
When I connect either of my 2 Ubiquiti UVC POE cameras, both port 1 and 2 are dead. Each of these cameras pull a max of 4.5 watts.
I will install the NG app and see if that helps.
Thank you for the welcome and for such a quick reply.
DickDay0
I updated the firmware. For some reason, I cannot get the GS to recognize the cameras.
Any suggestions? I read in one of the reviews that a user bought the GS105PE and was able to get his Ubiquiti UVC cameras to work.
It's been said that people over the age of 65 should not be allowed to buy any electronics without a note from their kids. I'm pushing 70, maybe it's true :)
- DickDay0Mar 19, 2016Aspirant
Sorry to drag this out, and I realize I am asking about another brand of equipment. If this needs to be moved to a different forum, or removed altogether, I understand.
This will be my last question... I am told that Ubiquiti's PoE does not conform to the industry standard, which is why your Netgear GS105PE does not recognize the Ubiquiti PoE cameras.
Ubiquiti sells something called an Instant 802,3af adapter that provides an industry standard PoE connection. I believe this in-line adapter goes between the camera and the pass-through switch, forcing the switch to see the camera.
Does any of this sound correct?
Thanks
- DaneAMar 20, 2016NETGEAR Employee Retired
Hi DickDay0,
DaneA
NETGEAR Community Team- DickDay0Mar 20, 2016Aspirant
That's what I assumed but thought I would give it a shot.
Thanks you.
