stuif
Jun 25, 2018Aspirant
IGMP snooping: Declare port and VLAN or not?
My ISP sends TV stream (VLAN4) and data (VLAN6) to my FTTH on which my router is connected. Behind my router I got my Netgear GS108Ev3.
On that switch port 7 and 8 are connected to my two televis...
- Jul 02, 2018
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jun 27, 2018NETGEAR Employee Retired
Hi stuif,
Welcome to our community! :)
Well, technically, it depends. It is much easier to configure the switch with a port-based VLAN and most likely if you want those ports not to communicate to other ports. Here is an article that may help you understand and configure port-based VLAN.
