stuif
Jun 25, 2018Aspirant
IGMP snooping: Declare port and VLAN or not?
My ISP sends TV stream (VLAN4) and data (VLAN6) to my FTTH on which my router is connected. Behind my router I got my Netgear GS108Ev3.
On that switch port 7 and 8 are connected to my two televis...
- Jul 02, 2018
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Jul 02, 2018NETGEAR Employee Retired
Yes, you can try to do a ping test so that you may know if it's still communicating with your TV. If not, then it is a success. Have you checked the article on my previous reply?
stuif
Jul 03, 2018Aspirant
Yes, your article helped my configging this. It is working now. I tested it to change VLAN ID4 to other ports my TV's are not using. Then the TV stops.
Testing using ping is not working, cause ping is using VLAN ID6 and that's open on all ports.
Thanks for your help!
