Arnaud_D's avatar
Arnaud_D
Inter vlan ping issues
Hello,
I'm setting a vlans
especially one for vlan management, all my switch answer the ping, and can be managed trough web interface, but 2 switches don't ping my pc and my pc can't ping/manage the switches, they're both GS752TS, my PC is in Vlan 110 and switches are in vlan 90.
When my pc is set in vlan 90 or vlan 1 it works fine, but in vlan 110 it doesn't work.
All my switches work fine, i checked the ip configuration, IP mask and gateway, they're correct. routing on M5300 work for everything else, the tag/untag is ok because  I can join my switches from another switch or a pc in vlan 90
But when my switches are set on vlan 90 (ip,mask,gateway, vlan id management) they cant leave vlan 90, but all the other switches can.
Thank you for your ideas ;)
PS: Sorry for my poor english, this isn't my primary language
  • Hi Arnaud_D
    Very gland to here you out of trouble now!
    I also think the configurations is right.Maybe it have something to do with arp-cash.
    Since your net is working fine ,just let us keep eyes on it.
    If question appear again please feedback,we are always pleasant to help you.
    Have a nice day
    Carl_z
    Netgear Employee
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi Arnaud_D
    Have a nice day
    Carl_z
    Netgear Employee
  • Carl_z's avatar
    Carl_z
    NETGEAR Expert
    Hi,Arnaud_D
    Welcome to Netgear Community!
    Can you please provide a topo of your network ,since I am not very sure about your topo from your description.
    Carl_Z
    Netgear Employee
ProSupport for Business
