BertAnsink
Oct 29, 2021Guide
Inter-VLAN routing MS510TXUP
Good day,
I am using a Netgear MS510TXUP multi gigabit switch. (not the MX510TXPP as selected in model, but can't select the MS510TXUP)
I am trying to use the VLAN routing functions, but with limited succes.
I have routing enabled.
If I use 2 VLANs:
VLAN1 = 196.168.1.0/24 with Interface 192.168.1.100
VLAN20 = 196.168.20.0/24 with interface 196.168.20.1
From a computer connected to VLAN1, 192.168.1.3, I can ping the interface of VLAN20 (192.168.20.1) but I cannot ping a computer on VLAN20 (192.168.20.2)
PC in VLAN1 has default gateway set to 192.168.1.100
PC in VLAN20 has default gateway set to 192.168.20.1
192.168.20.2 does show up in the ARP table of the switch. A static route is automatically added on the switch, pointing to 192.168.20.0
Is there something else I need to do to get inter-VLAN routing to work on this switch?
- DaneANETGEAR Employee Retired
Let me share the articles below and these might help as reference guides:
VLAN Routing on Smart Switches
VLAN Routing on a NETGEAR Smart Switch
How do I set up one or more VLANs between a NETGEAR ProSAFE firewall and a smart switch?
DaneA
NETGEAR Community Team
Hi DaneA ,
Sorry for the late response, I have been away from home for a while so only had time to dig into this again now.
The documents you posted post what I already did. I have set up the VLAN's and the routing table has the static routes, also the router.
I can not for the life of me get it to route between VLAN's, or acces the router/internet from any vlan except the one where the router sits on. I can ping the interface IP of the other VLAN, but then it stops there.
Is there any special setting I need for acces control?
I set the managment VLAN to another (99) but that is also of no help.
I apologize for the late response. :catsad:
It would help if you post a diagram of your current network setup as well as the configuration you did and from there, the community members might be able to comment their suggestions and recommendations.Regards,
DaneA
