AndreaLabel
Jul 11, 2025Aspirant
InterVLAN on GS728TP not working
Hello, I have a configuration with three different VLAN where I want to enable the routing between them.
The configuration is the following:
VLAN ID 10
IP 10.0.1.254 255.255.0.0
Port in the range 2-10 and every port have the PVID 10
VLAN ID 20
IP 10.0.2.254 255.255.0.0
Port in the range 11-16 and every port have the PVID 20
VLAN ID 30
IP 10.0.3.254 255.255.0.0
Port in the range 17-24 and every port have the PVID 30
If I try to connect a PC to a port belonging to VLAN10 and set up the network card as:
IP address 10.0.1.2
Subnet Mask 255.255.0.0
Default Gateway 10.0.1.254
I obtain response to the ping only from the gateway 10.0.1.254. No answer from the other VLAN IP e from every PC connected to those VLAN. I obtain the same result from any other VLAN.
The managmente VLAN (ID 1) is confined to port 1 and 2 of the switch.
I tried many times resettig the switch to the factory configurations. I tried to use the VLAN Static Routing Wizard and set up everything manually but nothing changed.
The Routing mode is enabled.
I saw that the routing table remain always empty.
I looked for a solution in many forum but i didn't find anything. Any Idea of what is missing? Thanks
The PVID alone is not sufficient - this defines only the VLAN where untagged incoming frames on the port will be associated to.
All ports for the relevant VLAN 10, 20, and 30 need to be defined as [u]ntagged - and associated only with one VLAN ID as [u]ntagged - and no other VLAN (eg. the default VLAN ID 1).
What hits my eyes is that all three networks and VLAN 10.0.x.x with the 255.255.0.0 mask are in the very same IP subnet - so not routing can ever happen.
- AndreaLabelAspirant
Sorry, there were some errors in the Ip the I wrote. I tried to recreate the case by creating distinct subnets. I attach some images to better clarify the situation. Each port in a respective subnet belongs to the VLAN only and has its PVID associated with it.
The default VLAN 1 is used only for managment porpouse in order to not interfere with the remaining VLANs.
If I try to connect a PC to a port belonging to VLAN10 and set up the network card as:IP address 10.0.1.2
Default Gateway 10.0.0.254I obtain response to the ping only from the gateway 10.0.0.254. No answer from the other VLAN IP and from every PC connected to those VLAN. I obtain the same result from any other VLAN.
