Mikeemikew
Aug 10, 2023Tutor
IPv4 Management VLAN Configuration
Any assistance would be appreciated.
IPv4 Management VLAN Configuration Parameters
Management VLAN Identifier: 99
Routing Mode: Enabled
Configuration Method: Manual
IP Address: 192.168.99.5
Subnet Mask: 255.255.255.0
Gateway: 10.75.10.1
Port Configuration:
Port 0/1 tagged for VLAN 99
Issue Description:
Although I have configured port 0/1 to be tagged for VLAN 99 and can access the Management page, I have noticed that I am still able to access the management page via the switch's IP address 10.75.10.2, which resides in VLAN 1. I had expected that this access would be unreachable with the settings I've applied. Is there something I might be overlooking?
1 Reply
- schumakuGuru - Experienced UserYou have enabled the routing, so out of the box there are no ACLs prohibiting the inter-VLAN access. Needles to say, this is different on switches without routing capabilities.
