zitsky
Dec 18, 2024Aspirant
Is wired ethernet a good solution for me? Does GS308E require subscription to work?
I'm thinking to use a Netgear GS308E to hardwire an Amazon Firestick 4K Max. I read that managed Netgear switches require an annual maintenance subscription to work, even home / personal devices? I...
zitsky
There's a small difference in price between GS308 and GS308E. Less than $10.
So you think there is no benefit to having a managed switch? It would mostly be for traffic to/from the Firestick 4K Max. And of course the point is to maybe improve the speed and stability of the connection going to the Firestick. The other traffic, internet audio to from a Denon X1800 receiver (maybe to/from a Plex server) and maybe built in apps on a Sony S6700 Bluray player would be minimal. So I could see your point that a managed switch is overkill.
Dec 18, 2024Guru - Experienced User
managed switches are great if you're needing to separate out traffic or needing more monitoring. But most people don't. So they log in, look at it, set it up in default, and never use it again.
- zitskyDec 18, 2024AspirantWill a 305e switch let you monitor network speed as well as prioritize specific ports? That’s what I’d like to do.
- RennaDDec 19, 2024NETGEAR Moderator
Hi zitsky,
Welcome to the NETGEAR Community! 🙂
With GS305E/GS308E, you would be able to prioritize port/s but not monitor network speed. Please see page 41 of the link below for more details:
https://www.downloads.netgear.com/files/GDC/GS105EV2/WebManagedSwitches_UM_EN.pdf
Have a lovely day,
RennaD
Netgear Team - RennaDDec 22, 2024NETGEAR Moderator
Hi zitsky,
We’d greatly appreciate hearing your feedback letting us know if the information provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Have a lovely day,
RennaD
Netgear Team
