Kelley
Dec 21, 2015Tutor
Issue with GS716T Switch
This morning we connected a Avaya IP phone (5621SW) to our network. It synced up as it was supposed to, but we started receiving calls about PC's blanking out. After some digging, it appears that all...
- Dec 22, 2015
Hello Kelley,
Okay, that's not the setup that I had expected. The model number of the phone was 5621SW so I thought the connection is PC>Phone>Switch. I have tried to look up some reported cases on the GS716T and did not find anything related. This issue is, I should say a bit weird since they are not using the same switch. But we'll start from the update of the firmware.
We'll wait for your update.
Thanks,
JohnRo
Dec 21, 2015NETGEAR Employee Retired
Hello Kelley,
Welcome to the community!
I understand that you are experiencing an issue with the GS716T in which PCs connected to an IP phone does not get a connection to your network, let me try to help you. I'd like to get as much information for us to isolate the issue, I have listed some questions below:
1. Do you have special configuration on the switch? (VLANs, QoS Profiles etc)
2. What is the firmware version on the GS716T?
3. What is the model number of the other switch (for comparison).
4. Is it a newly installed switch or has it been used before?
Looking forward to your response.
Thanks,
Kelley
Dec 22, 2015Tutor
Hi,
The problem was, we plugged a IP phone into our network through a Netgear FS750T2. This appears to have caused all the PC's on the GS716TV2 to lose their network connections (we were able to repeat this problem). No other switches or PC's on our network were impacted, just the ones connected to the GS716TV2.
1. No, there is no special configuration on the GS716TV2
2. Software version 5.0.2.16, Boot version is B5.1.1.1
3. Netgear JFS524 Model 23
4. the GS716T has been in service in the same place for some years now with no problems.
- DaneADec 22, 2015NETGEAR Employee Retired
Hi Kelley,
The FS750T2 supports data VLAN but not voice VLAN. A voice VLAN is needed to be configured on the switch for the Avaya IP Phone to be usable within the network. Voice VLAN is supported on the GS716Tv2 switch.
The JFS524 is an unmanaged switch. This is why when you replaced the GS716T with a JFS524 then connected the Avaya IP Phone to the JFS524, it had no impact. Kindly try to configure a voice VLAN on the GS716T switch then connect the Avaya IP Phone to it. Let me share this article as reference guide.
Let me also point out that the GS716Tv2 is using a very old firmware. You may want to do a ladderized approach to upgrade the firmware of it until it reach the latest firmware v5.4.2.19. Here is the link where to download the firmwares for the GS716Tv2. Be sure to perform a factory reset on the GS716Tv2 after a successful upgrade of the firmware.
DaneA
NETGEAR Community Team
- KelleyDec 22, 2015Tutor
Thank you for your replies. I guess I'm not making myself clear on the configuration here. The IP phone was never connected to the GS716T nor is it connected to the JFS524. It is connected for testing and setup to one of our FS750T2 switches (where it works fine for setup and testing). This is the only place it has been connected. The issue is that when the phone is powered on while connected to the FS750T2, it causes the devices connected (only PC's are on this switch) to the GS716T and only to the GS716T to go offline. None of our other switches (GS724T's, FS726T's, FS750T2's, among others), were impacted at all.
I understand that the firmware is very outdated and will work to update it.
- JohnRoDec 22, 2015NETGEAR Employee Retired
Hello Kelley,
Thanks,
