Foisys
Jul 29, 2020Tutor
JGS516PE: bricked after firmware upgrade
Hi, Just got myself a used JGS516PE from Ebay to power my Raspberry Pi 4 cluster and I got myself into trouble... Step by step: - Plugged it in, used ProSafe Plus Utility software to change its ...
- Aug 06, 2020
Hi,
Yes it did but I had to push the factory reset button longer than what iswritten in the manual... At least 10 seconds.
Best regards
S
Foisys
Aug 01, 2020Tutor
Hi to all,
Ok, after contact with Netgear support, it works again but I had to do multiple factory default resets to make it so...
S
- JohnC_VAug 04, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you can now access your switch after multiple factory defaults. May I know if this resolves your issue?
John
NETGEAR Community Team
- FoisysAug 06, 2020Tutor
Hi,
Best regards
S
