Foisys's avatar
Foisys
Tutor
Jul 29, 2020
JGS516PE: bricked after firmware upgrade
Hi, Just got myself a used JGS516PE from Ebay to power my Raspberry Pi 4 cluster and I got myself into trouble... Step by step:   - Plugged it in, used ProSafe Plus Utility software to change its ...
  • Foisys's avatar
    Foisys
    Aug 06, 2020
    Hi,
    Yes it did but I had to push the factory reset button longer than what iswritten in the manual... At least 10 seconds.
    Best regards
    S
ProSupport for Business
