giorgiop
Mar 27, 2017Aspirant
JGS524E-200EUS - Web management interface
Hello, I've just installed your switch Netgear JGS524E-200EUS ProSafe Switch Web Managed. Referring to the name I guess it should allow me to manage it through a web interface but the only istructio...
- Apr 02, 2017
Hello Dane,
I solved the problem.
The problem was due to the fact that I've first connected the switch to the power cable and only after a few time I connected the LAN cables.
In this way it didn't find the DHCP in the first minute thus it tooks its default IP addres and that's why I did't see it in the network.
To solve the problem I've turned it off and on again so it took the address from my dhcp and in this way I was able to access the web interface.
Thank you very much.
Giorgio
DaneA
Apr 02, 2017NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have questions.
DaneA
NETGEAR Community Team
giorgiop
Apr 02, 2017Aspirant
Hello Dane,
Giorgio
