jziggy101
Jul 08, 2019Aspirant
JGS524EV2 issues
I have a small network the starts with a Netgear 6700 router to provide internet connectivity to the network. The router is connected directly to the JGS524EV2 managed switch and provides ip address...
- Aug 15, 2019
Since the JGS524Ev2 only supports static LAG, it is recommended that you select XOR for the teaming mode. As reference, kindly access and read the article below:
ReadyNAS - What Bonding/Teaming Mode Should I Use?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
schumaku
Jul 09, 2019Guru - Experienced User
Should any current config lead to a network loop, issues with the router including the WLAN are predictable.
How are the switch port pairs for the NAS connections (and the NAS configured)?
How are the two ports configured which are used for the Windows 10 connections? Note: Windows 10 does not support any kind of LAG/link aggregation/bonding on it's own.
Suggestion: Start with a proper configuration of the LAG between the NAS and the switch first. Use static LAG on the switch (most Smart Managed Plus switches don't support dynamic IEEE 802.3ad LACP), Only TLB (transit lod balance), ALB (active load balance), or active-backup on the NAS would not require any switch LAG configuration. Balance-rr, balance-xor, or broadcast does require a static LAG config on the switch.
- jziggy101Aug 02, 2019Aspirant
Thanks for the response and I apologize for not getting back any sooner but I was travelling.
You say the JGS524Ev2 only support static IEEE 802.3ad LACP. If I setup the two Readynas (RN104s) for their ports bonded together what would be the correct MODE for the readynas bonded ports? Round-Robin, IEEE 802.3ad LACP, etc to get the best throughput?
- DaneAAug 15, 2019NETGEAR Employee Retired
DaneA
