jziggy101
Jul 08, 2019Aspirant
JGS524EV2 issues
I have a small network the starts with a Netgear 6700 router to provide internet connectivity to the network. The router is connected directly to the JGS524EV2 managed switch and provides ip address...
- Aug 15, 2019
Since the JGS524Ev2 only supports static LAG, it is recommended that you select XOR for the teaming mode. As reference, kindly access and read the article below:
ReadyNAS - What Bonding/Teaming Mode Should I Use?
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
jziggy101
Aug 02, 2019Aspirant
Thanks for the response and I apologize for not getting back any sooner but I was travelling.
You say the JGS524Ev2 only support static IEEE 802.3ad LACP. If I setup the two Readynas (RN104s) for their ports bonded together what would be the correct MODE for the readynas bonded ports? Round-Robin, IEEE 802.3ad LACP, etc to get the best throughput?
DaneA
Aug 15, 2019NETGEAR Employee Retired
DaneA
