michaeldaly600
Oct 26, 2023Follower
JGS524PE - ?can disable DDoS
The JGS524PE has Auto “denial-of-service” (DoS) prevention.
You don't seem to be able to turn this off.
But after extensive research, this seems to be causing problems with an ESXi backup as well as a storage reconnection.
ie it's seeing NFS between the NFS server and esxi host as DoS traffic
?anyway to turn it off
thanks
M
1 Reply
- ErikONETGEAR Moderator
Hello Michael,
This very much looks like an automated function and there are no options in the GUI to disable the auto-DDOS. In other words, we can't turn off the auto-DDOS function on the JGS524PE "Plus" switch.
Have a great rest of the day nonetheless,
Erik O
