JonathanTerry
Dec 28, 2016Aspirant
LanSweeper and Netgear Plus switch scanning
Started work for a new company that was still using old 3Com unmanaged 10/100 switchs and could not understand why they were having problems. Unwilling to spring for the latested and greatest in the...
JohnRo
Jan 02, 2017NETGEAR Employee Retired
Hi JonathanTerry,
Let me know if you have more questions. I'll try as much as I can to answer them.
Thanks,
- JonathanTerryJan 03, 2017Aspirant
Really appreciate your help. Hindsight is wonderfully 20/20. Really need a SNMP enabled switch for LanSweeper on the other hand they do have the ability to show Relationships so while I can't actually define and monitor based on Port and MAC address I can show what is connected to the switch with releationships.
- JohnRoJan 06, 2017NETGEAR Employee Retired
Hi JonathanTerry,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
