acte28
Nov 07, 2021Aspirant
Link Aggregation LAG with 40GB AOC breakout cable
I replaced 4 * 10GB ethernet cables to/from our core switch with an AOC breakout cable. From our core switch we are now connected with a 40GB QSFP+ AOC cable, and our office switch connected with 4 *...
schumaku
Nov 08, 2021Guru - Experienced User
At the end of the day it depends on what you want to achieve, what for these breakout connections are used for.
Technically, e.g. on a 40G port with a break-out plugged and configured, the core switch will have four individual 10G interfaces instead of one 40G:
core# show interface fec --------------------------------------------------------------------------------------------------- Name Ifindex Admin-fec Oper-fec Status Speed Type --------------------------------------------------------------------------------------------------- ... Eth1/3/1 0x38014000 auto auto disabled auto QSFP-H40G-AOC3M Eth1/3/2 0x38015000 auto auto disabled auto QSFP-H40G-AOC3M Eth1/3/3 0x38016000 auto auto disabled auto QSFP-H40G-AOC3M Eth1/3/4 0x38017000 auto auto disabled auto QSFP-H40G-AOC3M ...
These ports can be used to connect individual systems (needless to say, right ... think loop conditions et all), or if you intend to establish a LACP LAG it must be configured on both ends.
- acte28Nov 08, 2021Aspirant
Thanks for the reply and for your help!
The 40GB -> 4 * 10GB connection is only used to link our core switch to one of our office switches & using all four 10GB SFP+ ports. It's not going from our core switch to four separate devices.
In this case, would there be any advantage of configuring LAG on both ends?
- schumakuNov 08, 2021Guru - Experienced User
Yes, in my opinion we have to ... Otherwise you might end with a loop and port shutdowns.
