kurven
Dec 15, 2016Aspirant
Lokking for MIB file and/or OIDs for GS100 series SmartSwitches
I'm trying to set up monitoring for my network, and is looking for the OIDs for my switches (GS110TPv2 Firmware version 5.4.2.19 and a GS108Tv2 Firmware version 5.4.2.22) I've been searching every...
- Feb 17, 2017
Hi kurven,
I have sent you a PM with the new download link.
Thanks,
kurven
Jan 31, 2017Aspirant
Thank you for the download, unfortunatley this apears to be a firmware update with most of the files beeing in binary format with the exception of a few installation scripts.
Actually, I tried the NMS300 toolkit and it will suffice for my project, and I'm fully aware that unless any further documentation other than the source code is avaiable, I guess my search comes out fruitless.
Anyways, thank you for your time, I appreciate it.
- JohnRoJan 31, 2017NETGEAR Employee Retired
Hi kurven,
That was odd, the link should have contained the MIB files. I'll request it again. I am glad that the NMS300 is helping you at this point. I'll get back to you on this.
Thanks,
- JohnRoFeb 17, 2017NETGEAR Employee Retired
Hi kurven,
Thanks,
