GISGusting
Sep 07, 2018Initiate
MIB for GS510TP (again)
Hi,
Could I get a download link for the MIB of GS510TP switch, please?
Thank you
- Sep 07, 2018
Hi GISGusting,
Welcome to our community! :)
Here is the MIB for GS510TP. No password needed and the link will expire after 48 hour period.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Sep 07, 2018NETGEAR Employee Retired
Hi GISGusting,
GISGusting
Sep 09, 2018Initiate
Hi JohnCarloV
Thanks for your quick reply and the the downlad.
As I can see there is not too many request but I still do believe that it would be way more cinvenient to be available as download at the support site. When you are in the middle of a dev, it is a bt frustrating to wait even not too much.
Cheers,
Andras
- schumakuSep 09, 2018Guru - Experienced User
Andras, I can't agree more.
