vulogiccl1's avatar
vulogiccl1
Missing info on GS110TP
Hi
I have a GS110TP running  firmware  5.4.2.36 on a LAN  with several other switches, including two other, different Netgear switches.
Any network scanning or monitoring tools I may use on this LAN do not retrieve full information from the  GS110TP. Specifically, whenever a network tester identifies this switch, it will not display the switch's programmed  System Name and will display the switch model as "None", "No model" or "NA".
Here's an example of  a tester encountering the GS110TP:
(The System Name programmed into the switch is sw3, which is not being displayed below.)
Switch
Model
no model
IP/MAC
192.168.214.19
Port
g7
Type
LLDP
And here are examples of it encountering the other two Netgear switches:
Switch
sw2
Model
FSM726V3 - ProSafe 24 FE, 2 GE
IP/MAC
192.168.214.18
Port
1/0/11
Type
LLDP
Switch
sw1
Model
GS724Tv4 ProSafe 24-port Gigabi
IP/MAC
192.168.214.17
Port
g22,g22
Type
LLDP
I've reviewed the three switches and can't find anything noticeably different  in what I entered in their System Information pages, or in their SNMP settings.
How do I get the   GS110TP to divulge its "secret" information?
Thanks
CL
  • schumaku's avatar
    schumaku
    Reads to me as the tools you are trying do some basic things some IP stacks might discover, or use LLDP which is (as the name says) link layer discovery protocol which is never visible beyond the direct physical link.
    Configure SNMP on your devices, and use an SNMP capable tool.
    • vulogiccl1's avatar
      vulogiccl1
      The examples above are of the tester  reporting  its findings when connected directly to   port 7 on the GS110TP (sw3), port 11 on the FSM726 (sw2), and port 22 on the GS724T (sw1) -- three different tests, with  the tester physically connected to each device.
      SNMP is configured on all devices.
ProSupport for Business
