cam0001's avatar
cam0001
Motorola Cablemodem Assigning Public IP to Netgear Managed Switch
Hello,   I am using a Netgear 50-port managed switch (The model is GS750e), in which I created a separate 802.1Q VLAN that only has 3 ports (46,47 and 48).   The purpose of that VLAN is to cr...
  • cam0001's avatar
    cam0001
    Jan 23, 2019
    Thanks schumaku! Not the answer what I was looking for, but you're correct. I guess I'd put that VLAN on its separate isolated non-managed switch.
ProSupport for Business
