M4v3r1cK87
Oct 28, 2025Aspirant
[MS108EUP] - SNMP Protocol Integration
Hello everyone,
there is a possibility to integrate the SNMP Protocol inside the MS108EUP Managed Switch?
Thank you so much
1 Reply
G'day M4v3r1cK87
Well, no. By definition, this is a NETGEAR 8-port Ultra60 PoE++ Multi-Gigabit (2.5G) Ethernet Plus Switch, in no aspect a Managed Switch. Check the MS108EUP Product Data Sheet FMI.
Therefore, a moderator has moved your post to the appropriate products section, too.
Very different, the https://www.netgear.com/support/product/ms108tup on the other hand, does come with defined SNMP feature set.
