NRCAC
Jul 27, 2022Aspirant
MS510TX Rack Ears
Hello. I need a set of rack ears for this device. I'm in Australia.
- Aug 05, 2022
Welcome to the Community!
You can use part number 422-10047-01. The MS510TX has the same type of rackmount kit as the JGS series.
Thanks for the tag schumaku
HTH
NRCAC
Aug 04, 2022Aspirant
Thank you, I did so some time ago and have received no reply. I asked an Australian distributor who told me Netgear have no spare parts. I hope this isn't true, because it's a waste of a perfectly good switch. You'd think being an unconventional width Netgear may bother to supply rack ears for it.
schumaku
Aug 05, 2022Guru - Experienced User
A moderator here should be able to help - often see that they bring up a parts number for such parts (not listed in the standard catalogue). DaneA JohnC_V Marc_V JeraldM nice pleeeeeease.
Unless I'm very wrong, all four MS510 models use the very similar enclosure and rack ears - have not local device to compare (these belong to operations as you stated, too!).
