NRCAC
Jul 27, 2022Aspirant
MS510TX Rack Ears
Hello. I need a set of rack ears for this device. I'm in Australia.
- Aug 05, 2022
Welcome to the Community!
You can use part number 422-10047-01. The MS510TX has the same type of rackmount kit as the JGS series.
Thanks for the tag schumaku
HTH
Marc_V
Aug 05, 2022NETGEAR Employee Retired
HTH
- NRCACAug 08, 2022Aspirant
Thank you Marc V, very helpful! Do you know which of those on your eBay link is appropriate? 10 of the 11 look identical it seems...
