NRCAC
Jul 27, 2022Aspirant
MS510TX Rack Ears
Hello. I need a set of rack ears for this device. I'm in Australia.
- Aug 05, 2022
Welcome to the Community!
You can use part number 422-10047-01. The MS510TX has the same type of rackmount kit as the JGS series.
Thanks for the tag schumaku
HTH
Marc_V
Aug 05, 2022NETGEAR Employee Retired
HTH
NRCAC
Aug 08, 2022Aspirant
Thank you Marc V, very helpful! Do you know which of those on your eBay link is appropriate? 10 of the 11 look identical it seems...
