evanc9126
Mar 31, 2020Aspirant
MS510TX trick to getting routing to work correctly
Hello, I am having great difficulty getting the routing and vlan routing setup on my switch. I have the latest firmware installed which is 6.7.0.42 and am using the web interface. In the user m...
- Apr 01, 2020
Welcome to our community! :)
This type of switch can only work with VLAN routing per interface. It does not support all the members of the VLAN as it is only a L2 switch. If you wanted to have VLAN routing working on all of the devices, then you may need a fully manageable switch.
John
NETGEAR Community Team
JohnC_V
Apr 01, 2020NETGEAR Employee Retired
John
evanc9126
Apr 01, 2020Aspirant
Thanks for the welcome and thanks for the reply. I was under the impression that MS510TX was a L3 switch due to its routing capabilities. I guess I misunderstood when reading that chapter in the manual. I thought that enabling the routing mode under Routing > IP > IP configuration meant changing it from L2 to L3.
Looks like I will have to do some significant reconfiguring on my network to deploy this thing then as the plan was to replace the Cisco switch. I wanted the 10 gbe capability and MS510TX was the most affordable option for my needs.
