hdewitt001
Dec 08, 2021Aspirant
MS510TXUP - POE doest not provide what is needed by Internet Access Point (Aruba 555)
Not sure if it is the same, but I have a MS510TXUP with Power Over Ethernet. I am using an Aruba AP-555. It needs approx 38watts to fully operate. However, when I look at the power consumptio...
WilsonS
Dec 23, 2021NETGEAR Expert
Hi hdewitt001
From the Aruba is see the following information:
LLDP Power : Successfully negotiated at 40.0W Current Operational State : No restrictions (Overridden by LLDP) Eth0 HW POE status : POE BT, LLDP power: 40.0W Eth1 HW POE status : NONE, LLDP power: 0.0W
I think the Aruba AP is getting necessary power from MS510TXUP without issue.
Power negotiation is one thing. However, actual AP's power consumption is another thing. For example, when only few packets go through the AP, the AP will comsume less power. Could you have maximum loading (maximum traffic throughput) to the AP's 5G and 2.4G bands? Will it increase AP's power consumption?
hdewitt001
Dec 23, 2021Aspirant
Not really. I have tried different settings, with two or three radio's on.
It feels like, that when it notices power, it gets to a minumum mode, and that is 13 watt. While it needs more, but is not asking more, as the AP doesn't ask anymore.
I strongly believe it has to do the LLDP connection, that the Netgear POE isn't able to communicate well with the Aruba. I asked Aruba, and they told me that there no settings I can configure or so, as it should communicate that it needs class 5, and 40w. As you can also see from the pictures I added to my post.
The router by the way, is a Ubiquiti UniFi Dream Machine, which has also a lot of settings. Not sure if that can impact the info that is shared between the Aruba IAP and the Netgear POE switch.
Thank you for your questions.
- WilsonSDec 26, 2021NETGEAR Expert
Hi hdewitt001
The Aruba AP has done LLDP communication with MS510TXUP and successfully negotiated at 40W. MS510TXUP cannot push 40W into AP forcedly. The AP pulls the power from PoE switch based on the AP's actual power consumption.
1, Could you ask Aruba why the AP only consumes around 13W when LLDP result is show as abvoe?
2, Could you ask Aruba how the AP can consumes more power and even to 40W?
3, Turnning on radios is not equivalent maximum load. Could you add maximum load to all radio bands at the same time to see whether AP's power consumption gets increased (ex: testing it with iPerf on multiple PCs) ?
