PeterG10
Oct 18, 2025Follower
My Netgear POE switch FS728TP is on but no POE activity
I had 2 of these switches for several years working fine! I just discovered that though the switch is on including the lights of the POE it still does not provide any POE activity when I plug in a de...
schumaku
Oct 19, 2025Guru - Experienced User
This pushbutton allows to change the logical display if the relevant LED on each port only, the LED mode LED indicates the mode only.
Suspect the PoE controller or the relevant power supply might be broken.
Head to https://my.netgear.com
for your FS7yx model and serial number warrant terms.
