switchbaby
May 10, 2021Aspirant
NETGEAR 8-Port PoE GS108PEv3 Software Question
SO im new to switches, I work from a Macbook Pro I only need to wire internet into 6 rooms. nothing complicated but id like to be able to control the mb in each room if i need to (allocate more int...
switchbaby
May 11, 2021Aspirant
and will i be able to access the software from my mac?
As shown before, the management is done using the Web UI and a Web browser.
can you tell me how?
do i just open a browser on my mac and go to the ip address??
this is what im unsure of
schumaku
May 11, 2021Guru - Experienced User
switchbaby wrote:and will i be able to access the software from my mac?
Permitting the Mac and the switch are on the same IP subnetwork, yes.
