notqytryt
Oct 31, 2023Aspirant
Netgear FS728TPv2 PNP
Can I just use Netgear FS728TPv2 as plug and play without using the configuration control center... just need the switch to power a couple poe cameras added to my home network.
notqytryt
The reolink cameras are plug N play.. I just now have to figure out how to get the switch to go into "open mode"... (meaning do I have to configure it with software or just reset it)
schumaku
Oct 31, 2023Guru - Experienced User
With the default config, there is no port security, no ACL, no 802.1x - works like any generic (unmanaged) switch.
- notqytrytOct 31, 2023Aspirant
Thanx I was hoping that was the case... I just need the poe ... the switch was cheaper for me than 3 adapters.. and this is definitely an easier way to go....
