lerouxluc
Dec 08, 2015Aspirant
FS728TPv2 After upgrade to 5.0.2.39 wweb interface not working
Dear all,
Here is the problem, I have upgarded the switch to 5.0.2.39 from 5.0.2.25. No errors during the process, but since then, I have lost access to the web configuiration interface.
Can't connect tu the swich for to configure it any more.
What should I do and how?
Downgrade to the old version? Flix this version problem?
Thanks for your support in the mather.
Luc.
Problem fixed.
Using the SmartControlCenter, I found that a valid DHCP address is not assigned to the switch. Default address 192.168.0.239 is assigned instead of a valid address for the subnet I have installed the switch on.
Using SmartControlCenter I could discover the swich and its incorrect address and assign a valid fixed address. I can now access the switch.
Problem fixed!
1 Reply
- lerouxlucAspirant
Problem fixed.
Problem fixed!
