notqytryt
Oct 31, 2023Aspirant
Netgear FS728TPv2 PNP
Can I just use Netgear FS728TPv2 as plug and play without using the configuration control center... just need the switch to power a couple poe cameras added to my home network.
notqytryt
Can I use the Netgear FS728TPv2 as a simple plug N play switch for a home network? if so. Do I have to have the software to disable any settings in the switch. I need the switch for POE cameras. I hope this question is pretty clear
notqytryt
Nov 06, 2023Aspirant
One quick question . Can I connect poe and non poe devices to the switch without having to disable power to the ports that will not be connected to poe devices. The manual doesn't really describe this process
- schumakuNov 07, 2023Guru - Experienced User
This is part of the standard for IEEE PoE - there won't be power applied if there is a standard non-PoE device plugged.
