Nicolas31
Mar 01, 2017Follower
Netgear GS105PE - power available on PSE
This switch is powered throw port 5, by 802.3 af or 802.3 at. I want to use the port 3 and 4 for computers (no problem), and use port 1 to get back power in DC to provide power supply to an electric...
- Mar 02, 2017
Hello Nicola31,
Welcome to the community!
You'll have to make sure that port 5 (PoE PD) is getting the correct amount of power. When port 5 (PoE PD) is powered by a device at 802.3at specification, you should see a green LED light (right side). See scenarios below:
If the PoE pass-thru is enabled you should get 19W with 802.3at/7.9W with 802.3af input power.
Thanks,
JohnRo
Mar 02, 2017NETGEAR Employee Retired
Hello Nicola31,
Thanks,
JohnRo
Mar 06, 2017NETGEAR Employee Retired
Hi Nicola31,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- Feb 22, 2022Retired_Member
