Murrayfield
Oct 03, 2023Tutor
Netgear GS105PE firmware upgrades
I have a number of Netgear GS105PE switches in my network which were all running FW V1.6.0.6. They were all happily behaving themselves (I know if it works don't fix it) but I thought hey lets upgra...
- Oct 05, 2023
Hi Kurt
Many thanks for the extremely detailed explanation, yes you are correct, in both cases I am powering the GS105 switches from GS108v3.
I did experiment with daisy chaining 2 GS105 PE (again upgraded to V1.6.0.17 from a single port (4) of a 24 port NETGEAR JGS524PE-100EUS but again this did not work. When I downgraded the GS105PE it supported the second GS105 in the daisy chain, so as you say I must be operating right on the limits, good to know.
Given that prior to upgrade everything worked, albeit as you say in a potential fault scenario, I propose to revert all my switches back to V1.6.0.6 and document the ratiionale for not upgrading to V1.6.0.17. That way if it ever goes flaky, I or whoever comes after me will have a guide as to the reasoning.
Given the way these outlying bits of my network are architected it is extremely difficult to get 240V to either the switch or the camera without incurring a great deal of expense but I will note for the future.
Many thanks again for your time and trouble
Regards
Ian
schumaku
Oct 03, 2023Guru - Experienced User
Everything very vague. Report lacks of the PoE source used to power the GS105PE, lack of information of the PoE Webcam, ...
The GS105PE Firmware Version 1.6.0.17 Release Notes does show, among others:
Bug fixes
- Fixes the issue where port 5 incorrectly adjusts PoE power requests from the powered device (PD).
Worth noting, the long standing GS105PE: PoE troubleshooting remains valid.
So yes, something changed in this area, but it's difficult to follow up your report I'm afraid.
Murrayfield
Oct 04, 2023Tutor
Hi Schumako,
Please see the following
1st Scenrio webcam going off air
Netgear GS108 PEv3 firmware level V2.0.5.24 PE port 4 connected to GS105PE running FW V1.6.0.6 port 1 connected to Axis M1125 Camera all working fine.
Netgear GS108 PEv3 firmware level V2.0.5.24 PE port 4 connected to GS105PE running FW V1.6.0.17 port 1 connected to Axis M1125 Poe port 1 shuts down
2nd scenario Wireless access points shutting down
Netgear GS108 PEv3 firmware level V2.0.5.24 PE port 3 connected to GS105PE running FW V1.6.0.6 port 1 connected to Netgear WN370 and port 2 connected to Netgear WAX214 all working fine.
Netgear GS108 PEv3 firmware level V2.0.5.24 PE port 3 connected to GS105PE running FW V1.6.0.17 port 1 connected to Netgear WN370 and port 2 connected to Netgear WAX214 both shutdown.
It is almost as if the upgrade has reduced the power budget on the GS105PE.
If push comes to shove I will just document this as an issue with the sw upgrade and leave the switches on the working version
Many thnaks
Ian
