ColinDexter
Jul 08, 2018Tutor
NETGEAR GS108PE-300EUS and IPv6
I Just have bought a GS108PE-300EUS. But it seems it doesn’t support IPv6? I had expected that all new devices already had IPv6 support.
I have seen that there is newer firmware. If I install this,...
- Jul 10, 2018Hi, Thanks for your help. I have found that the setting “Block Unknown Multicast Address” blocks the IPv6 . Best regards, Colin
DaneA
Jul 09, 2018NETGEAR Employee Retired
Hi ColinDexter,
Welcome to the community! :)
I'm afraid to inform your that GS108PEv3 switch only supports IPv6 Passthrough and this is not a limitation.
To know the NETGEAR switch models that supports IPv6, kindly access the link below then scroll down on the right side pane then click on "IPv4 and IPv6 Support" and check IPv6 Management, Routing & Security.
NETGEAR Product Switch Selector
DaneA
NETGEAR Community Team
