ColinDexter's avatar
Jul 08, 2018
NETGEAR GS108PE-300EUS and IPv6
I Just have bought a GS108PE-300EUS. But it seems it doesn’t support IPv6? I had expected that all new devices already had IPv6 support. I have seen that there is newer firmware. If I install this,...
  • ColinDexter's avatar
    ColinDexter
    Jul 10, 2018
    Hi, Thanks for your help. I have found that the setting “Block Unknown Multicast Address” blocks the IPv6 . Best regards, Colin
ProSupport for Business
