ColinDexter
Jul 08, 2018Tutor
NETGEAR GS108PE-300EUS and IPv6
I Just have bought a GS108PE-300EUS. But it seems it doesn’t support IPv6? I had expected that all new devices already had IPv6 support.
I have seen that there is newer firmware. If I install this,...
- Jul 10, 2018Hi, Thanks for your help. I have found that the setting “Block Unknown Multicast Address” blocks the IPv6 . Best regards, Colin
DaneA
Jul 10, 2018NETGEAR Employee Retired
I have seen that there is newer firmware. If I install this, does this almost solve the IPv6 problem?
Let us try this. Since you have seen that there is a new firmware, I suggest you to update the firmware of the GS108PEv3 switch to the latest version which is v2.06.03. You can download it here. Be sure to perform a factory reset the GS108PEv3 switch after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, check if IPv6 Passthroguh will work on the GS108PEv3 switch.
DaneA
NETGEAR Community Team
- ColinDexterJul 10, 2018TutorHi, Thanks for your help. I have found that the setting “Block Unknown Multicast Address” blocks the IPv6 . Best regards, Colin
