IT_Dad
Oct 22, 2020Initiate
Netgear GS108Tv3 Radius Authentication To Ubiquiti USG
I am new negtworking and I am trying to setup a GS108Tv3 Netgear Switch to use the Radius server on a Ubiquiti Secure Gateway(USG). My hope was that anything connecting to my netgear switch will hav...
- Oct 22, 2020
First configure the RADIUS server on the switch, e.g. Security > Management Security > RADIUS > Server Configuration for the RADIUS authentication server.
Then you can enable 802.1x on the switch port - that's all straight forward. However, carefully check the fine documentation on configuring. Don't forget to put the dot.1x authentication list to RADIUS. Security > Management Security -> Authentication List -> Dot.1x Authentication list.
IT_Dad wrote:My hope is that any device connected to the ports that I configured for dynamic VLAN would get a web page popping up to authenticate but I don't get anything asking me to put in a password.
No Web page at all... There must be a 802.1x supplicant on the computer connected and properly configured. Most settings are related to the RADIUS server itself, the switch does only hand over the 802.1x packets to the RADIUS server.
schumaku
Oct 22, 2020Guru - Experienced User
